Using a Comet style backing plate is often times easier than making an actual long jackshaft that goes across the width of the bike. But clearance can be an issue because of the size of the plate.
But don’t forget, if you are not using a driven and driver from the CVT, you could trim quite a bit from the rearward portion of the plate, since instead of a 6 in driven you will be using smaller sprockets.
Don’t forget about a cover, you’ll need that to keep your leg from getting chewed up.
Maybe a predator would be easier in the long run
Good point where could i get a cover?
