My son races a outlaw class with 120 snowmobiles. The only rules are no exotic fuels and max 212cc. I just bought a used modified clone with the following done to it.
Hemi predator block
De-stroked +.17 clone crank
+.20 arc billet rod
Pvl flywheel
Gx200 billet lifters
Chromoly push rods
Nr racing 247 0207 cam
18cc Honda head
Ss 28mm intake 25mm exhaust valves
Milled.80
26lb springs
Champion rockers
This motor was ran with a .650 bored stock appearing carb and nr intake with pulse fitting. I cannot use either because it will not fit in the chassis without serious modifications to the tunnel. As a alternative I have found the inverted intake for a 22mm mikuni. Has anyone has any experience with this intake and also will the 22mm mikuni be sufficient enough for this build? I'm assuming so if a stock appearing carb was used but not sure. Also if it will work well what is a good starting point for jets? Thanks
Hemi predator block
+.20 arc billet rod
Pvl flywheel
Chromoly push rods
18cc Honda head
Milled.80
26lb springs
Champion rockers
