I bought a Motovox with a predator 212. I want to drag race this bike. It's certainly fast now, but I want to go just a little further with it. I am wondering in what order to make some of the mods I am considering. Below is the description from the ad:
- High Flow Air filter
- Larger Main Jet
- Larger Pilot Jet
- NR Racing Camshaft
- Upgraded valve springs (do not remember spring force but they match the camshaft)
- Governor removal
- Aluminum Flywheel
- Flywheel Key advance (6 degrees)
- Straight pipe header (with header wrap)
- Gold Oring Chain
- Quick Change Rear Sprocket
- New centrifugal clutch with proper spring and weights
- New Street Tires (much better grip)
- Larger Main Jet
- Larger Pilot Jet
- Governor removal
- Aluminum Flywheel
- Gold Oring Chain
