This Saturday is a Super Saturday race out at Milan Dragway. I worked on the bike last night. Re-did my chain tensioner and got rid of the idler sprocket. Now it's a spring loaded wheel style. Should work ok, but a couple of high speed passes will be necessary to make sure the chain is staying put. Next up was replacing the steering neck bearings. Out of an abundance of caution I put in new bearings. Didn't really feel any better, but I did tighten the neck bolt a little more than normal. That should help take out the neck shakes. This bike does not turn much. Last thing I did was to mount the steering damper. I just used bolts, one through the bottom triple tree and one to the flat panel on the front of the old motovox's. I need one more nut and maybe a couple of washers and that will be done. If I have time I'd like to make up a fork brace. Come Saturday I hope to make full out straight passes, no shimmy, no shakin, no gettin squirrely at half track, and the chain to stay on all the way down to the end! Pics tomorrow.
