So I am getting around to the jack shaft area. The rolling Taco 44 chassis came with a jack shaft bearing still in the left side and nothing in the right side. Figured I would replace them both. Got some new snap ring 5/8" bearings from Azusa. Tapped out the old bearing on the left side - it was a nice tight fit. Tested a new bearing on the right side and it is a rather loose fit. I can wiggle it enough to make a sound against the bearing holder / frame.
Took some pics and both sides are not exactly perfectly round, but at least the left side is a tight fit. On the right side I was able to slip a .013 feeler gauge between the bearing and the bearing holder / frame.
Soooo Googling around I have seen some possible solutions mentioned -
1. Use a small punch at several points around the bearing holder / frame to distort some metal and then Loctite the bearing in. Not crazy about this idea.
2. Try to find a slight oversize bearing that will fit tight. Have not been able to look yet.
3. I saw these things mentioned somewhere but know nothing about them - https://www.mcmaster.com/catalog/118/1163 Scroll down to Ball Bearing Shim Rings. Anyone have experience with these?
4. While on the Azusa site I saw the BEARING HANGER part they sell. See https://azusaparts.com/product/bear...38-id-x-3-od-with-2-mounting-edge-x-14-thick/ . It occurred to me that I could just have one of these welded right next to the existing bearing holder / frame. Could even do both sides. That would give me a nice round tight fit on both sides.
Would be open to what you all think. I know solution #4 is sacrilege to mess with the original frame but it would be the strongest solution.
Is this a common problem on these old frames?
