I am thinking I may need a rejet of some sort, but what do you think?
Motor is completely stock, with a helper spring on the governor spring, stock air filter and airbox, stock exhaust pipe but muffler box is broken off. Essentially just a closed end pipe with 3 holes drilled in the side of it.
When cold, the motor fires right up on the first pull and I can open up the choke completely almost immediately. Rides around good and is responsive.
After a little while, once the motor gets up to temperature, It wants to die when it drops back to idle. Fairly often it will just cut out at full throttle (as if I let off the gas) and die, and when it dies it is hard to get started. When I do get it running after a bunch of pulls, I usually have to have the choke half closed or so and the throttle cranked a little bit in order to keep it from dying.
Oil level is good and oil is pretty fresh 10w30 synthetic. Oil sensor is disabled. 87 octane fuel.
I want to say this seemed to be more prevalent when the welds on my stock muffler broke and the box came off...but its been a few months since i had it out so thats just a guess more than anything.
I need to read the plug and see whats goin on, but having to close the choke halfway to help keep it running when hot makes me think its not getting enough fuel?
