Soooo finally I got those pictures of the intake and exhaust porting! It took me forever I know! Been busy with Work, life, the usual excuses for not posting! So this was all done by hand with a dremel and some sandpaper!
Intake
Exhaust
Now theses aren't done per say, but they'll have to due for now.
Now I also made the new intake manifold, well for the most part! It's alot better then the original plastic one! This piece took forever to get right though, but I had alot of patience! To get the tabs for the bolts right I would have to go out of my garage, well walk through two two car bays, and make a tack weld to hold the tab then walk back to my desk cool the piece off and test fit it and then find out it was off by an 1/8 I would break off the tab, re mark and walk back!! Did that like 6 times! But hey I had alot of patience.
Here is the other piece to the manifold being held up, I will cut the piece to the correct length when the engine is mounted on the frame, then weld it together!
I also got some steel rims that I will be using! They are really heavy duty and should work out fine. I'm not to excited to drill the 12 holes that will be necessary for mounting the rear pulley, I'll explain later!
Some welding on the frame! These are terrible welds! ! I did then quickly, so I'll go over them again. That's the neat thing about oxy-acetylene welding is that you can go over a weld a few times reheat it and smoothing it out also ensuring that the weld penetrated deep enough!
A new pedal hub
Some strengthening of the rear axle mount!
