Bearing Update : Ok the Motovox and the db30 models all share the same fork neck bearings. I read in a thread where the fork bolts are the same as well so you can use one on the other ,except the DB30 bolt has a taller head so to use it on the Motovox you have to either grind it down shorter to miss the bottom of the Motovox handlebars ,or use taller risers. I Just thought I would share this. And placed my order already Thanks Again OldMiniBikes ...My daughter said the same since this is her minibike.
