So my MTD Trail-Flite has had a problem with the head tube since i got it. I suspect that the bike was previously crashed and repaired.
The headlight brackets were bent flat. The footpegs were collapsed, and there is some extra welding done on the head tube.
I noticed the forks were not very tight. I tightened the fork bolt, and the next day it was loose again. So i left it alone but over time it was obvious that the head tube is now banana-shaped.
They did a decent job on the repair, but i suspect that they used thinner than stock tubing. There is a visible wrinkle in the head tube and a straightedge shows that it is severely bent.
https://imagizer.imageshack.com/v2/640x480q90/922/AWzLoZ.jpg
Gonna get a short piece of DOM tubing of a thicker wall but same OD so that the bearings will fit. Cut out the old piece and TIG in the new piece.
I was wondering if anyone could take a measurement of the head tube in degrees? In relation to the top frame tubes being level?
If not i will just figure it out, thanks!
Also planning on beefing up the frame a little bit and the forks and swingarm so the shocks have 2 mounts instead of 1.
