So I'm putting a 6 hp. Tecumseh on my BC 1100 which requires me to use a jackshaft with the first sprocket on the outside of the bearing plates. So I decided to build a clutch cover that was wider to accommodate the sprocket although I ended up building it to stock size. Yesterday I asked the forum for the measurements and after [MENTION=44497]Bonanza BC1300[/MENTION] gave them to me I started to build one from pictures. I started with a oil tank end cap stamping I got from Paughco that turned out to be the correct size other than the dome is a little flatter. I then rolled a piece of sheet metal and welded it on. Next I made the chain guard part with rolled edges like the pictures show. I just need to put the holes in it now
