Knocked it together pretty much just so see what it sounded like. Used a 3/4 nipple, 1" EMT, and an empty propane bottle. Drilled out holes in the inner pipe until it looked like Swiss cheese, bent them into little scoops with a screw driver, packed it with fiberglass, and tacked it all together with a AC stick welder (not the right tool for the job!).
Sounds pretty good! A little lower than the previous Briggs hotdog muffler, yet the thump is more noticeable. Puts the outlet another foot farther back as well.
If I end up rebuilding it, I'll probably cut the rear cap off further forward, weld up a band to go around the tank, then use a couple sheet metal screws to hold it all together. Should be neater and make it easier to repack. If the fiberglass breaks down too quickly, I might try stainless pot scrubbers.
