I'm using a drum brake on my Cat Endura project with a lighting Tec. and brake/tail lamp.
I've seen the Rupp switches, but no idea how they mount, and not sure if it's a good way to do it. (Smash and O ring and short across contacts?) Definitely don't know where to mount it.
Since the brake arm/lever is top mount, the traditional spring-loaded pull switch won't work- I could weld a fulcrum to the bottom of the arm, but I'd end up hitting it in a turn maybe.
Are there any other ideas, or projects you guys (and gals) have tried that worked well?
