Hey guys,
New member here from Va. I really need some help getting my minibike up and running for the first time since rebuilding.
My build is as follows:
Predator 212 Hemi
-governor removed
-Arc Billet Rod
-Arc Flywheel
-Mod2 cheater cam
-22mm valve springs
-header exhaust
-Mikuni 22mm slide carb with K&n pod filter
Stock Main Jet is 95...replaced with 110 size jet....Got to idle okay. but stall and cuts off immediately once i give it the slightest bit of throttle. I have very little carburetor tuning experience so and advice would be appreciated...
-Would going up in main jet size possibly fix the issue?
-Does gravity feed fuel tank deliver enough fuel?
-Would installing a pulse pump do any good?
Predator 212 Hemi
-governor removed
-Arc Billet Rod
-Arc Flywheel
-Mod2 cheater cam
-22mm valve springs
-header exhaust
