i just picked up a 1980 can am 250 qualifier dirt bike and need a couple of question awncered like on the clutch side with all the gears dose it use oil in there if so what type took the cover off today and there was no oil tto be seen just woundering if it used oil or not im pretty sure it dose but just want to double check. what mix should the gas and oil should be?and there a fitting on the gear box on the motor near the chain i saw what sopose to be hooked up there i saw in a you tube video a fuel line coming out of it if so were dose it go to
im use to working on boats and vintage sleds im just starting to get into dirt bikes so need a little help
