I got my old flathead running for my blue bike this weekend just to pop the head gasket.(This is the bike in my avatar) I thought I torqued it to the correct speck so im not sure what went wrong. This motor has been refreshed and has big valves now. It was idling pritty well on full choke and I was playing with the carb to get it idling without the choke (It needs a richer idle jet now) and it sputterd out then would not re start and felt like it had no compression. I cant wait to see what difference thise valves make! fast is fun!
I also just started re assembly on an ohh55 Tecumseh 5hp flathead (late model without points) This is a mild build, it has a billet connecting rod, porting, a 275 lift cam, stronger valve springs, a header and the govenor is removed with the hole plugged. I'll be looking into a mikuni for it at some later point but for now im sticking with the stock carb to get it running quickly.
As far as the bonanza I need to downsize the holes around the exhaust before I can mount it. the current holes have been hogged out to 3/8ths and need to be re sised back to the origenal much smaller m6 size in order to mount the pipe. I bought some aluminum 3/8ths bolts from my work and am having the center of them tapped out to the origenal m6 size. as far as the Pipe, before I came up with the fix I mentiond the hole issue to the pipe builder and asked if he could make a flange to match what I had and I guss it was one request to many and he said no to making me a custom pipe so I'm on my oun on this one even thow Im fixing the flange issue he dosnt care and said as much. I have a spare flathead pipe I got cheep at a flee market and im going to cut a pice out of it to extend the ohv pipe I have up the 1 1/2 inches I need to to get the pipe to fit the bike. I dont like waisting a perfecly good header but I don't have many choices hear and Im on a deadline.
At some point this next week I need to get the bonanza frame over to A local welding shop to have the footpegs mounted. Im not very good at welding and my welder isn't fully set up yet so Im taking this to the profeshionals. The footpegs I have aren't even close to the origenals But finding origenal stuff for a bonanza seems imposible right now as most of it is either non existent or priced threw the roof and these are a quick fix.
