Hey everyone, back in the game again. I'm starting a new Briggs build, my first one, I have everything torn apart right now cleaning and degreasing it. I'm planning on doing a mild build on this one. So far I have removed the governor, threaded a 1/4-20 bolt and red lock tighted it in the hole. I measured the piston pop out and I'm .006" below the deck, I'm am going to be shaving the head since it's fairly easy to do. How much should I take off? I was thinking .015-.020".
Also I shaved the eyebrows, ported intake and exhaust.
Parts list is. Billet flywheel, billet rod, duel valve spring kit, new piston rings, billet lifters and a bigger cam ( leaning toward a 94ss cheater cam) and a 22mm mikuni carb.
With that being said, does anyone have suggestions on what else I can do or other parts I should use???
I will post pics of stuff later on....
Thanks
Thanks
