I have not tried the Dellorto/Lambretta 19mm clone carb yet. I did get a good solution to the choke though. But i need to get an intake manifold to try it.
I would like to say this though... the 16mm Mikini clone carbs on Ebay for $10-20 are really working out quite awesome. They adapt very easily to the stock intake manifold. I use an aluminum extender, because it keeps the throttle cable away from the exhaust. But i guess you don't have to do that.
But the more Tecumseh HS50 motors i mount these 16mm carbs, the more happy i am. They really give a nice performance increase, without much money or time. You get way better throttle control, opposed to the tecumseh carb (where the throttle is really just on or off, without much middle play on the throttle control). And the high end is way improved. Also the governor is not used on these. (I pin it towards the PTO, so there's no stress on internal governor components.) Also just the general feel and motor responsiveness is much better. The choke is perfect too. The HS50 starts right up with this carb, first pull (choke on.) The set up looks cool too!
https://www.ebay.com/itm/Carburetor...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Here's my Gemini that i just mounted the 16mm carb upon. I was riding it around on the trails with the stock carb (new china clone tecumseh carb), and it was running just fine. But then i decided to install the 16mm, and wow, what a difference. For all of $30 (including the air cleaner and a new throttle/cable assembly), there really is no better "bang for buck" modification.
Again, i use the Dellorta Ua19 as used on the Rupp black widow as my bench mark. The 16mm is not quite as performance as the Dellorto, but frankly, it's pretty close. And a hell of a lot cheaper/easier to get! I also have a bike with a Dellorto Ub22 (22mm). It performs much like the Ua19. But runs a bit too rich (a lot of back fires), and chews a lot of gas! But even that solution is at least $100 (if not more). So these 16mm carbs really are the best thing going for a nice Tecumseh mod (without much money or time investment.)
Also with the 16mm carb, there's no jets that need to be changed. Really the only adjustment needed is to the idle screw. It's ready to go out of the box. I use an Amazon throttle assembly (comes with a cable), and this works really well and is inexpensive.
https://www.amazon.com/gp/product/B01MPX353V/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
