Im no expert, just speaking from ive done and learned. Mine is setup alomost just like the pic of mooses'. Flip 180, you mean your cable is in front of the clutch? That might be the problem, its spinning is forcing the band open, maybe? Again im no expert, and I may have misunderstood what you meant by 180. Hope this helps.
Here is a pic of mine before I put a new band and fine tuned it a bit.
[/QUO
You are correct, the cable is in the front of the clutch. So maybe you're right. I'll flip it around and see if that helps... it totally makes sense :doah:
Dave: What do you mean " The band itself is the rubber one from Northern Tool" what is rubber on them? Do you mean the pad itself?
jeep2003: Yeah I guess maybe I put it on backwards :shrug: it appears the force of the clutch would be trying to "open" the brake :doah:
KK: "I think sometimes the band gets glazed from heat and it severly affects it's effectiveness"
That's what I was thinking.... maybe I needed to scuff the inside of the brake pad or the outside of the clutch housing :shrug: But I'll flip it around and see if that helps. This is my first time really messing with a clutch style band brake... so live & learn I guess :doah: But if I can get it to work well it I can use this method on some of my other mini's :thumbsup:
