D, heres a small lesson in jackshaft ratios... say youre running 12/60 (5:1 ratio). If you put a jackshaft on that has say 10 teeth on the input and 10 teeth on the output is is EXACTLY the same as running a 12/60 ratio since they cancel each other out. Same with if you had a 12/60 ratio and added a 20t on the jackshaft input and a 20t on the output it would be the same 5:1 ratio. Now when your jackshaft sprockets are different teeth sizes then you'll have to do some calculating. My tip doesnt help much, but it really helped me out in understanding ratios.
