Being new to this forum, I'm not quite sure the best place to post this, but I'll try here.
Back in 1988 I acquired a 1972 Z50 that came in a number of boxes of parts. The engine and transmission were all torn apart. I rebuilt the engine/tranny and it's worked quite well ever since. However, it was time for a make-over which included new rings as it was smoking quite a bit.
After that, it did start and run for a few minutes, then kept dying getting harder and harder to start until now it just won't start. Also, it was misfiring the last few times it ran.
Here's what I've done so far:
1/ installed a new plug
2/ cleaned carb
3/ checked spark (nice and bright blue)
4/ checked flywheel to make woodruff key hadn't sheared and thrown the timing off
5/ checked transmission breather vent wasn't clogged (driving oil down the intake valve guide)
6/ checked cam timing and lash (intake only so far... will check exhaust too)
7/ checked compression and got 90 psi, however that's typical with my compression gauge when using it on a small displacement engine as it has a long hose between the gauge and spark plug hole adapter which absorbs pressure. So before it reads right, the piston has run out of air. Last time I did a comparison, that 90 would be more like 125 to 130)
8/ with carb off, I tried gas, then a little propane and then a small squirt of ether down the intake port. Didn't fire.
I'm out of ideas, at least temporarily. Any thoughts on the matter? Thank-you.
2/ cleaned carb
