Picked this up at an engine and tractor show last week. Its a 1961-62 H22 (2 1/4 hp) just before they transitioned to the typical engine tags, and started to ween themselves off the lauson (and power products) name/s. While some of these engines were in use on earlier mini's, the side saddle tank version like this was not from what Ihave seen in this particular timeframe. So I figured I would pull that stuff right off and have it available for a Rupp cub/econocyle/racsal/chopper, or chevy Jr. Kart and convert it to standard shroud if its something worth messing with internally, basically use the fuel tank to partially fund the build
With some fuel It kicked, but didnt want to run. I figured the timing was off among other things, so I decided to tear it apart and have a look. Someone did have it apart, Looks like to maybe try and revive it from sitting not becuase of damage, but didn't know what they were doing. Valve faces sandpapered/rough but valve seats untouched (exhaust pitted pretty bad), They had a piece of tape with a line drown on it stuck to the flywheel, and when I popped the wheel you can see where they had the mag screwed down everywhere but the right spot I will give the credit though, the flywheel, snout threads, and nut were still fine.
These early built engines had the pinned valves, and used tiny springs compared to the later small frame H/HS engines got.
Guides came in halfway on the cutters pilot seen stuck in the exhaust guide, so thats a good thing.
Full teardown, showed pretty well other than the valves and seats, nothing was out of spec or really damaged as I measure everything as I remove to see just how bad its gonna be. Note the Wico made ignition system, Some hardware, and stampings on bolts are different than typical 1960's-early 1970's engines too if your looking to restore or replicate an early engine.
While this one is a non bearing supported, splash lubricated, they still had the oil pump versions available at that time so this one has the Hollow camshaft that also worked on the oil pumpers.
Off to the vertical lathe for journal surface prep
comparing the springs to later models (bottom) you can see quite a difference in size:
Started working out the kinks, I got the block stripped, worked out the deck warps (I will maybe do an article on some of the changes that Tecumseh did in the middle/later 1960's to address that problem as noted in some Technicians literature) Recut the valve seats in a 3 angle cut trying to keep it at a minimum, debured the ports and recut the original valves for a fresh, tight fit.
and finally for today ( I gotta get the final prep/block out work done on a customers engine so I can paint it hopefully in the next 2 days) I got the cylinder prepped.......I love a good crosshatch
