Old School Welding Processes
nightgrider
So I know there's a lot of really knowledgeable people on this site and I wanted to pick your brains on some welding processes that don't get mentioned a lot these days. Carbon Arc Welding, has anyone on here tried it or have experience?
nightgrider
Please forgive my ignorance, but it is a similar to gas welding but fueled by electricity instead of gas, right? The carbon arc torch to make the weld puddle. Then you use a filler rod to fill?
Good question. The carbon "electrodes" that came with my cheap arc welder made a "flame" about the size of a golf ball. It would heat an area, but I could never get it concentrated enough to make a small puddle. It did well for brazing It was more like a rosebud tip on a torch for heating and bending.
nightgrider
Probably about as much as one could ask for, at least with a home machine.
Bird Brain
Had a teacher in middle school touch on the topic of using the carbon rod stripped out of an old dry cell battery clamped on a welding lead to cut aluminum. Said it works however ive not tried it personally. Now that im 50 plus and he was about that at the time i might should just for grins.
I kinda doubt you would get two piece of metal worth keeping. Please let us know what happens if you do try it. Theoretically, you can sharpen those carbon rods in a common pencil sharpener.
Bird Brain
Sharpe
Sharpening the carbon rod in the pencil sharpener was added info given to me by the teacher and was a detail i ommitted to mention in my post. The possibility of using a car battery and jumper cables in a pinch was also discussed. Great catch Sparkwizard.
I have 6 deep cycle 12 volt batteries under my work bench. They are charged by wind and solar. They power some 110 volt inverters for the different barns and buildings...blah, blah, blah....
I have used jumper cables on those batteries to arc weld some leaf springs together. I might try a carbon rod, just because we NEED to know!
nightgrider
Inquiring Minds Want to Know. Haha
