one lash cap missing
chadillac
hey has anyone had a lash cap fall off the valve and go inside the engine cause I seem to be missing one. is that possible. or did I just miss place it.
chadillac
I know but I had one on the intake I got from nr has anyone had one fall off. and MY rockers keep loosing off I just put a 14cc head on my gx200
Motra
The spring retainer is different too, did you replace it? If you put a lash cap on without replacing the retainer, it probably will fall off.
chadillac
well I did find it it fell down inside the head at the bottom of the pushrod good thing I looked down in there before I put the thing back together.. I have a campion power eq engine has a different rocker setup. so now with the 14cc head switch I got the chance to use my 1.3 rockers. man this thing is a rocketship now. it flys it was had to start at first was ripping my arm off. so I took the sharter rope winder off and just rapped a rope around it at and no more ripping my arm off. ran well:thumbsup:
