one of a kind 3hp Briggs
chain
New Member
I've lost interest in this project and moved to another. I'm selling the complete motor, with carb,custom cam, flywheel, tach, and puke can. It is still considered a project.. still needed is a gasket set, breather, and custom exhaust for your build. Everything for the inside is new except the crank. Will throw in valve lapping tool and Briggs compression wrench for rings. I'd like to get 350.00 o.b.o shipped cont. 48 Here is the build thread.......
http://www.oldminibikes.com/forum/project-logs/74295-boardtracker-build.html
chain
New Member
OK here is a picture.
Listed as shown
3 HP IC Briggs
3 SM Flo Jet Carbs 1 is completely rebuilt 5hp with genuine Briggs parts
New Auto Meter JR Dragster Briggs Tach with instructions
JR Dragster Race Car Engineering 3HP Billet Flywheel
Dymo Cam Custom welded and ground cam (94 ss profile this alone was 150.00)
2 NOS Briggs Rods
NOS Briggs wrist pin
NOS Briggs Piston
NOS Briggs Chrome Rings
NOS Briggs Rings
NOS Briggs Coil
NOS Briggs lifters,valves and springs
stock crank
BMI aluminum over flow tank
BMI Clutch/Chain gaurd
6 feet USA made fuel line
Pull start cup
Briggs Valve lapp tool and compression wrench for rings will be included. I am definitely open to offers on this.
chain
New Member
I was sanding the frame and found a spot on the drive side chain stay that was rusting from the inside out, there couldn't have been a worse spot. I'm going to use the rest of the parts besides the frame for another vintage Whizzer. If I don't get any action on the lot, I may part it out. Im open to offers.
