Got a lot of work done the last few days.
Powder coated the fan shroud and side cover
Also clearanced the block for the lobes on the cam
Installed the seals and bearings into the block and sidecover
All the new parts waiting to go in the block. 2.815" wiseco piston, .175 arc stroker crank and rod, oversized billet lifters from isky, and an isky .310 cam
Stroker crank, rod, and big bore piston in the block, milled for zero deck height
Lifters and .310 cam from isky in
Studded, gasketed, and all bolted up. Bottom end is done now
