Hello,
I have a bigger bore HS50 where the bore was worn so I bought a .010 over thick ring piston and rings for it. Brought block to machine shop with piston and rings and they bored it out.
After installing the piston and putting everything together, the piston is too tight in the bore. Or should I say, the rings are too tight, the piston with no rings seems fine.
I’m not sure if the machine shop honed the block afterwards, but I didn’t before assembly.
When I put the top ring in the bore, there is like an 1/8” ring gap which to me seems wrong. Seems like a huge gap would be looser, not tighter. So I am guessing that I have the wrong rings.
I have a smaller bore HS50 piston here with thick rings, when I put one of those rings in the bore the gap is much better.
If I use the rings from the smaller piston and everything seems good, is that ok to run the motor with?
Thanks
Thanks
