Hi.I have a 22mm Mikuni carb on a 212 predator.My question is how do i tune it to idle at lower rpm?Right now its idleing at 3250 rpm, and my clutch engages at 3000 rpm. So it takes off by itself.
Detroit on the side of the carb ( opposite of the choke ) is a little brass set screw , it raises and lowers the slide. Back it out to slow it down in to speed it up .
make sure the slide is all the way down before you even attempt to start it again. did you trim the black casing on the throttle cable before you put it together? if not the cable isn't long enough to allow the slide to go down all the way.
