Guys, sorry to respond so late on this, I have not been keeping up on this tread. You may be able to get the needles from Bobby Muha (601-317-2249) he has quite a collection of Power Product parts. If he can't help you then get a set of loose needles for a West Bend 610/820, they measure the same diameter (.093) but are too long (.4825 versus .4170). I have a set of pliers that I ground a grove longways to hold the needle, I grind the ends on a belt sander equally on each side to get the required length, bevel the ends a little.
I say loose needles because US Motors (West Bend) also use a caged bearing for the crank end of the rod. For you West Bend guys (610/820) do not use the caged bearing in a kart or mini-bike application, they have been failing when being used above 7000 rpm. You can use the 610/820 wrist pin in the Power Products, they need to be cut to the proper length (1.594).
Power Products started to use the double row needles (56 needles) in the later engines, the single needles (28 needles) were used in the earlier engines.
