I recently installed 22lb valve springs on my predator 212cc engine and set valve lash to .007 on exhaust and .003 on intake and I made sure the cam and crank shaft were timed and everytime I try to start it, it doesn’t start anyone know why?
Why did you set the exhaust so loose? (.007) Where did you get that number? You will be defeating the compression release. In addition pay very close attension to Strigoi's post or you will get the pull start cord ripped out of your hand.
You still have your exhaust lash too loose. This is a common issue because folks dont set it right or set it a few degrees after TDC on the overlap stroke not the compression stroke. You can set the exhaust lash as tight as .0005.
