Predator 212 performance issues
#61
I think you misunderstood my question. Why did you state that the tach should be set in the 2 cycle mode (and not the 4 cycle mode) when the OP has a 4 cycle engine?
Michael
I said that because his Predator fires on every revolution, not every other revolution. The numbers he posted looked like about half of what he should be turning. If his tach is programmable for 2/4 stroke and number of cylinders, like most tach that run off the primary side of the coil instead of the secondary, it should be set for single cylinder, 2 cycle.
