Hello, I searched around but could not find what i needed to get kids go cart going. I bought a predator 212 from a young man but the throttle linkage was junked. Starts and runs great using carb throttle by hand. I ordered stock linkage/springs and rod. I also ordered the cable mount that goes on recoil. I have linkage hooked up to governor and carb but the throttle plate is not pulled shut. You can pull the linkage but the throttle plate is already open. I never saw this when it was correct so i cant figure out what pulled it closed. Is governor supposed to have spring tension on it pulling the carb shut? It just moves back and forth wiht no tension. Maybe there is another spring im missing? Any wisdom would be great. thanks
