I recently bought a few upgrades for a predator 212 non hemi. I got a chikuni, 22 lb valve springs,header pipe, aluminum flywheel. the cam is stock the rod is stock and I kept the stock key in for the flywheel. it is making a sound whenever the valves open and close. I have lashed the valves twice and pulled out and re inserted the pushrods. I domt see any thing binding up inside the crankcase. also another mod is the I have a pulse fuel pump hooked up and the pulse fitting is on the top of the valve cover. I took the valve cover off and it still made the same noise. sorry for my bad explaining skills. thank for the help in advance
Is ALL the internal governor parts removed from block???
A push rod bent??
Are pushrods same length??
Pull em back out and roll em on a flat surface, look for bends.
Lash cap(s) installed???
Coil bind in the springs??
Retainer to rocker clearance???
Bent pushrod guide plate???
Valve lash set to .003" ??
If find it best, before setting valve lash, is to make sure head bolts are tightened to torque spec. 17 ft/lbs for stock.
These engines will still run with a leaky head gasket. Sounds like a really low whistle.
Thinner then .045" head gaskets, needs washers under the head bolts for a good seal. These engine are not perfect, when it comes to changing parts, check and then check again.
Since you are using the crankcase vent for fuel pump, do you have another vent for crankcase now???
The crankcase still needs to be vented with a check valve. If not, it will start building too much pressure and pop a seal or gasket.
