I'm pretty sure the gaskets are not set up properly on my engine ( greyhound 196cc) as I found two were stacked on top of one-another.
Is there a clear drawing of the gasket on the intake manifold, back side of carb(intake side) and front side( air filter outlet) of carb?
I need a clear view of each gasket to make sure they are correct for that position and not covering up any bleed holes and the like.
Thank you for your help.
