I put everything back to original. The dowel pins are different sizes so any gasket I put in ended up not sealing right. When I get another gx160 head or my blue clone head milled I'm try figure how to make the bigger dowel pins from the predator fit in other heads and get alot of predator head gaskets. Yeah its not a big deal to me if I make any mistakes. I like trying different things.
I don't understand.
You lost the correct dowl pins?
No matter with or without the head should seal.
You should be using a Preditor head gasket from the start.
Preditor pins or non at all and that head should seal if its flat.
Sometimes I have issues with sealing and use a spray on head gasket sealer with the steel rings.
Alternately there are aftermarket head gaskets that will seal.
If you go back to Bob's 4 cycle send a PM to " SNEAKS ".
He has all kinds of copper head gaskets.
95% sure he already has something for this motor combination and if your real nice he might have some pointers for you.
Tell him Oldschool sugested you ask him for advice.
