I have a predator with a billet flywheel,springs,long connecting rod and adv key way and it will run good for a couple seconds and then shut off. i dont have the oil sensor in it. What is wrong?
I started it with out the air cleaner on it and i drilled out the jet already cause i put the after market filter on it. It has never ran just put it together this winter.
No 2 motors are the same. Even if their built the same. If that makes any sense. Lol. Check your plug. It might not be burning up your fuel correctly. plug might get hot then goes out. :shrug: check coil gap too. Other than that maybe try another carb.
