I need some help......I have an azusa mini bike that was put together from a kit.....Its the one with 5" aluminum tri star wheels AZ 1144 and I am using the AZ 2218 ID 72 tooth sprocket and brake drum.......I cannot get the sprocket to spin even close to true.....the sprocket wobbles and even causes the chain to tighten and loosen severely I tried to disassemble the wheel and check to make sure the parts are all fitting together correctly and they seem to be correct I also tried to clock the sprocket in a different position on the 3 mounting bolts, the aluminum rim itself seems to have a decent wobble to it? are these azusa wheels just very poor quality? am I not using the proper sprocket 4 1/2" brake drum with the wheel? any suggestions? is there a better 5" wheel brake setup that fits in the AZUSA kit frame?
