Project ideas?
#21
It's not diffucult to widen a frame...which may be what you want to end up doing so you can fit some wider wheels and center the drivetrain.
Here's how I like to keep my torquey engines from sliding around when I use slotted engine-mounting plates...the bolts make it easier to set the chain or belt tension, too...they hold the engine where you want it while retightening the mounting bolts.
#22
It's not difficult to modify or build a minibike frame, and it really makes it easier in the end to get a bike that functions well with the other components you've chosen. Plus, you can use or add custom touches...
I think the next one will be made from a few hundred feet of barbed wire...this one is 23 ft of tow chain.
Go for it, guys...you've built some cool engines...make a cool frame to match...
For welding info, I got to:
www.weldingweb.com
For metallurgy info and heat-treating tips I use:
www.abana.org
Both of these sites have free forums where users can ask specific questions and get answers from knowledgeable professionals.
