Hello, I was hoping to get a little help from you guys. I'm working on this Baja that I have had for about 5 years. I swapped out the engine for a Predator 212 (non-Hemi), I have a GTC TC2 torque converter, aftermarket exhaust, 2" air intake, carb jetted to .036 as my current set up, nothing crazy... Every year I like to put a little something on it for the season, it keeps it fun and I enjoy working on it. I just put the new motor on last year, so it has only has 5.7 hours on it.
This year, I wanted to take it up a notch so I picked up an ARC 6695 flywheel, 6256 rod, a DJ-1103P CAM, and some 26lbs valve springs. This is my first dive into an engine however I'm feeling confident. Just wanted to see what your thoughts would be on this. If you could share any tips to make this smoother, any other things I should be keeping in mind or upgrading to make this set up work better? Like some question I keep asking myself is, should I offset the flywheel and if I were to, what degree would be optimal? Will I be getting enough fuel out of the .036 jet? Anything else you guys can think of I'm open for all suggestions. Thank you!
Edit*
I'm assuming not to offset the flywheel as it's set to 32 degrees already, but with the DJ-1103P cam would it make a difference if I did offset it?
Edit*
