Proper spark plug gap?
Fisher1983
What is the proper plug gap for a lightly modified Predator 212? The manual doesn't say. I have a Hemi with a header, billet filter adaptor, Uni filter, number 90 main jet, and a .016 pilot jet. After I jetted it today, it felt soft on acceleration. I checked the gap and noticed it was smallish at .027. I opened it up to .040 and it felt better but I'm still wondering what a safe range is. I'm still running the factory Torch plug until I purchase an NGK BP6ES. Edit: also worth mentioning the engine retains the governor operating at 3800 rpm on a stock geared DB30.
Get a new plug. it should be gapped from the factory. The stock plug sucks.
Opening the new plug to .040 is ok, but the stocker won't last long.
Fisher1983
I'm going to stay with a standard plug since I don't have a racing engine. It doesn't turn enough rpm or run hot enough to benefit from a multi electrode design. I'm just surprised the factory manual doesn't say the gap...
My predator is stock and has the Autolite plug above....
The benefit is a great plug that you won't ever have to worry about again. Put it in and forget it.
Blazer cranks on
Iin my experience Low power ignition systems like what are found on single cylinder industrial motors, like a ground electrode that is ground or filed to a point, Also use a high preformance plug wire. get the fuel right,
If you do this the voltage requirement to spark drops and you can open the gap a bit for a bigger spark.
Opening the gap requires more voltage so go a little at a time.
Bbasicly your gapping the plug to the systems voltage capability so when you start to experiance misfire stop and back up a bit, THAT will be the gap your motor wants not what some book or person says.
Read ohms law. ionization and how lightning is made.
