Pulse fuel pump install
I am installing a fuel pump on a predator 212. If I install the pulse fitting on the valve cover do I still leave the breather tube in place or remove it ?
Leave the breather tube in the valve cover , drill your hole on top of the valve cover close on the exhaust valve side . Get you a 1/8th inch npt fitting with a 1/4 inch hose barb on it , tap the hole with a 1/8th inch npt tap . You can buy this stuff at most of the automotive stores or hardware store.
Had one set up like this, which is what OND is describing. Worked fine, had no issues. Was on a clone in the pre-Predator days, but that really doesn't matter. The small red filter is coming from the breather hole on the valve cover.
