Black mamba cam
Honda flat top piston
file fit rings
ARC billet flywheel
ARC billet rod
ARC billet gx200 to gx390 carb adapter
GX390 Carb
Velocity stack + air filter + choke hold bracket
8mm plug wire
champion rockers 1 to 1 ratio
chr push rods
raceseng guide plate
28.5mm intake stainless steel valves 25mm exhuast stainless steel valves
head milled approx .030
.010 head gasket
Grade 8 head bolts
Auto lite racing sparkplug
Promod underseat exhaust with RLV muffler and clamp
2 Disc tomar clutch in excellent condition (3500-3800 rpm engagement)
600$ local pick up, It's jetted perfectly and makes incredible power.. My estimate is 17-19hp... I hit 8200 rpm with this on my mini bike was scared to twist it anymore... Nice crackle and loves shooting fire out the exhaust on deceleration
Really easy to pull start and fire's up the first pull. Approximately 10 hours on this engine, it's too fast for my application would be great for a drag mini bike. Replaced exhaust studs with sturdy socket head bolts, intake manifolds and gaskets are air tight, and will gladly demo the engine. Great engine just drop it in and go.
Will accept paypal (only if shipping), bitcoin, cash, thanks.
Here's a little video of some idling and revving
https://youtu.be/A02kqyJ1LD0
file fit rings
ARC billet flywheel
ARC billet rod
GX390 Carb
8mm plug wire
chr push rods
.010 head gasket
Grade 8 head bolts
