I'm trying to remove neck bushings from an Bonanza BC frame. I thought I could tap,tap,tap from opposite end with a long screwdriver and get them out. No dice. :hammer: Even tried a few whacks. Tried propane torch heat on the neck, along with whack,whack, whack :hammer:. That was probably dumb since doesn't bronze expand faster than steel? Anyway neither the top or the bottom have moved at all.
Do I need a pilot bearing puller? I just don't see how that would work either, I don't know what would support or hold it on the outside of the neck.
Any experience or advice?
Thanks, Ken
Edit: or do I need something like this?:
New abi Enduro Cartridge Bearing Puller | eBay
There is barely a lip I can feel on the inside. Do you just squeeze this thing in there past the lip and try to pry it out?
2nd edit: I just noticed this section is under the "engines" heading so my question is probably in the wrong spot. I'm not exactly clear on where to ask questions. :shrug:
Thanks, Ken
