Removing the big block bump
125ccCrazy
The big block covers without a bump are getting a little harder to find in good shape sooooo....... I have a nice solid cover with a bump and a not so solid cover without the bump... The donor cover was all rusted out on the bottom more than likely from sitting in the dirt or some old damp floor...I started to repair it but decided it would be of better use as a donor...... I also welded up the fuel line holes..... the pics pretty much cover the rest...
125ccCrazy
Thanks Owen.... I couldn't trash the cover just because of the bump since it
was solid, just surface rust but yet I wouldn't use it on a bike with the bump...it's not perfect but most people will never know once it's painted...
This one had an electric starter too.I tapped the gear off the flywheel and got rid of that bump too.
I think they look better without the bump too and that cover you did looks real nice.:thumbsup:
oldfatguy
I found a vertical shaft cover on ebay to replace the rusted out one that came with the engine. I like it because it didn't have the fuel line holes. The repair that you did looks great, nice work
:thumbsup:
