What type tap did you use...bottoming or plug? Thanks for your time....
Thanks
Dave
Thanks
Dave
Now for the last thing, what about drilling/taping the PTO? You know, so you can put on a clutch and bolt it in place (opposed to set screws.) This is pretty easy. The PTO is cast steel, which in reality, is pretty soft (and self lubricating while drilling.) Since we're going to go with a 5/16-24 screw size, you'll need a 5/16-24 tap and tap handle. You'll also need a couple drill bits (1/4" and 17/64", though technically, it's really a letter "I" drill bit, but 17/64" works fine.)
You also need a centering tool. I bought mine from McMasterCar for $15. It works well and is drilled for 1/4". (insert name of tool and part number here.) You just slide the tool into an old clutch, put it on the PTO, and drill 3/4" deep into the PTO shaft. (The clutch is just holding the tool in place, it serves no other purpose in this exercise.) Then remove the clutch and tool, and use the 17/64" bit to enlarge the hole slightly. Then tap it with the 5/16-24 tap. Now your PTO is ready for a clutch. All you need is a 5/16-24 bolt and washer.
