So on hs40 orange motor, with the 1 inch PTO shaft, I was wondering if you can use an H35 crankshaft in place of it? Are they the same? Because I have a number of h35 short blocks I could steal the crankshaft, as an easier way to get a three-quarter inch PTO on the HS40 motor . The three crankshaft I showed in the pictures a few posts Back are for an HS50. I’m pretty sure those will not work. Also since this is a point and condenser model motor, the fly wheel is slightly different the tapered is cut differently. The three hs50 cranks I have are for solid state ignition hs50 motors, which won’t work on point and condenser model motors
