.007 to .017 end gap. Openings are spaced 120 degrees out from each other. Orientation doesn't matter. I do oil ring to the left, compression center, then top compression to the right.
The Tecumseh 3 to 11 HP manual is on line in PDF. (Less than ten bucks on ebay too)
Oh forgot- flat (right angle) side of the rings goes up. Angle goes down.
Replacement rings have compression rings of two different thickness' so far. No idea why. They fit the same. Hope someone can answer that. I haven't had any problems with it, but I do wonder.
