I bet these engines are never rebuilt, probably take a lot and abuse and last forever. Of course, after someone hops it up for racing, that's when the trouble starts LOL's.
Pull the pump housing and have a look see at the PTO. May have a weird end that won't take a clutch, if so you may be done. :shrug:
If you like 2cycles, there are some really good old kart engines out there for not much. You can get them for maybe $200 or less and used to be able to rebuild for $300. They generally make approx 15hp plus or minus. One problem, need expensive clutch to run.
I see them on cl and ebay from time to time. Watch for these 100cc piston port engines: Komet K-71, TKM BT-82, Yamaha KT-100. There are also other piston ports, reed valve, rotary valve up to 135cc. Some are starting to become vintage, so prices are getting too high to mess with.
I have 6 TKM BT-82's, some running some not.
TKM BT 82 116cc Go Kart Engine Blueprinted Fast Runs Great Reliable Motor | eBay
