Disreguard the in info on the bike in the add, as it is incorrect/fake (notice the wording "had you have ben a member already, you could have taken advantage of our steal of the month"
. but here is what the bike looked like for the most part new. You will get better stopping power with the foot brake rather than a cable/lever. And while I will agree that a jackshaft is a better setup for less chain troubles. that particualr bike did not come with one. But if you did utilize one, you want to try and put your input (from engine) on the outside left since you are restricted to left side output only due to brake. Most bikes of that era that is a problem, but since they are forward peg frames, that would not create a problem to do, plus you can better center a big powerplant in the frame that way if you did it.
