For Sale
This is a custom modified Tecumseh 10 HP LH358 iron sleeve engine that fits a Rupp Roadster2 mini bike and more with about 15 minutes of run time, all it needs is a stock era correct recoil, air filter and it's ready to go. I was trying to build a smoother running that stock engine with high HP at lower RPM's it didn't work out that way so I took a different route. Everything is there slant intake, fitted carburetor with linkage, billet side cover with ball bearing PTO, TC cover mounting bracket, 84 watt power, this comes with a bunch of extra parts including a new fitted replacement crankshaft, new +.010 piston and rings, 4 sets of replacement rings, low use STD piston with rings and rod, multiple gaskets and any other parts I have the fit. $200 plus the ride.
Tony
Tony
