The material they used is a seamed tubular material with odd dimensions. It's similar to 3/8" black pipe.
LENGTH = 1.960"
O.D. = .665"
I.D. = .475 -.485"
I took other dimensions from this area just for the heck of it.:
Both these bolts are grade 2 on mine
SPROCKET BOLTS = 3ea. 3/8-16x3"
REAR AXLE BOLT 1ea. 5/8-11x7-1/2"
SPROCKET DIMENSIONS:
DESCRIPTION = 60T #35 CHAIN
THICKNESS .148"
I.D. = 1.755"
BOLT HOLES = .390"
SPROCKET BOLT PATTERN
ABOUT 3.245"-3.250" I GOT THIS DIMENSION BY MEASURING THE BOLT AND CENTER HOLES THEN MEASURING THE DIFFERENCE BETWEEN THEM AND COMPUTING THE CENTER-TO-CENTER OF THESE HOLES THEN MULTIPLYING BY TWO.
I think they were shooting for a 3.25" bolt circle, but when I measure these things I'm also measuring manufacturing errors along with 50 years of abuse.
The wheel bearings are stamped 1.375" x 5/8" x 7/16" (nominal, not actual dimensions.)
These bearings are easy to find and cheap to buy. I got all new solid ground, and fully sealed bearings with snap rings instead of stamped flanges for both wheels for $14 shipped. If you are trying to achieve a faithful restoration you can get the stamped ones even cheaper.
Any other dimension you need I'd be happy to supply.
Thanks,
Tom
P.S. Sorry for all the CAPS.
